O2 sensor bad again
O2 sensor bad again
Well had a P0172 (rich condition) come up on my 2010 LT 2.2L HHR... When my car was in the shop for a lean condition. IT was traced to the upstream sensor not reading right and fuel trim readings not where they should be. Put new one in and everything was reading like it should. Four months later its now reading rich and it pointed to the same sensor (upstream) not reading correct again. What would cause a sensor to go bad in a matter of months.
Fuel pressure, bad injector, dirty MAF, cracked flex pipe, burned valve, MAF connector
https://www.obd-codes.com/p0172
https://www.obd-codes.com/p0171
And remember; rich does not always mean rich. Here is one of many results from "fuel trim" in Yahoo, it is really involved.
https://search.yahoo.com/yhs/search;...&hsimp=yhs-004
Short Term Long Term Fuel Trim Explained
