oil flow
Old Oct 27, 2014 | 07:10 PM
oifvet138's Avatar
oil pan
Well today as I dropped the oil PAN I found pieces of black plastic and a bolt in the bottom of.the oil pan and some up in the screen. Cleaned it all out will keep u updated!
Old Oct 27, 2014 | 08:24 PM
Snoopy's Avatar
I would be REAL concerned about the material found in the pan. Had to come from somewhere......right.
Old Oct 27, 2014 | 10:50 PM
fastsuv's Avatar
The black plastic sounds like the fixed timing chain guide. I found the same black pieces and a broken-off bolt under the timing chain cover (from the disintegrated chain guide). Is the bolt you found broken off or complete with threads?
Steve
Tommyy626
Dec 2, 2010 09:21 PM
JJ's BLACK SS
May 19, 2010 06:57 AM
