Oil Leak Alternator Pulley? What?!
Old Apr 23, 2022 | 08:34 PM
lhaluciol's Avatar
Angry Oil Leak Alternator Pulley? What?!
Hey guys!
Just got a 08" HHR 2.2 with a whooping 250K miles. Still going strong!
Previous owner really took good care of it but...
...Some oil on the floor in my driveway! After following the leak up, it leads me to the highest point being the alternator. See picture below.
I can see a lot of oil on the pulley and even inside the alternator itself. I know this type of alternator does not need oil. so...I'm a bit confused.
The serpentine (which needs replacement) might be picking up oil from somewhere.
I don't know the "usual" things that break on this model so I'm asking you before I start pulling parts!
Any help is appreciated!
Thank you.
Old Apr 23, 2022 | 09:10 PM
Lonwane's Avatar
I would not be suprised if the oil is being thrown up there.
Check the crankshaft seal behind the harmonic balancer.
If it's not the Genuine GM seal it usually leaks
That usually throws oil at 2500 rpm or so.
Old Apr 24, 2022 | 06:23 AM
X2 ^^^^^ crankshaft to harmonic balancer seal.
I suggest you change the serpentine belt and the tensioner as a set at this age the spring in the tensioner has relaxed a bit.
Old Jul 3, 2022 | 08:36 PM
lhaluciol's Avatar
Thanks both of you! It was indeed the crank seal. All good now and no more leaks!
Old Jul 4, 2022 | 05:10 AM
Awesome, thanks for your follow up and confirming it was the seal for the harmonic balancer.
Ronnie
Maintenance and Upkeep
26
Sep 23, 2020 01:56 PM
billmac77
Feb 20, 2019 05:51 PM
Vera234
Feb 3, 2018 12:05 AM
Nazramoth
Oct 11, 2016 01:04 PM
DaytonaBlueMetallic
Mar 13, 2013 12:07 PM
