Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Hey, this is my first post here, but I've been reading the site for about 2 years!
I'm replacing my oil pan gasket today and wanted to see which of the two that I bought you guys would recommend. These are the two types that I bought.
Des either of them state that they are replacement for GM 12378521? I suspect the Victor Reinz is the same thing.
torque to 18 lb ft
The tightening sequence
torque to 18 lb ft
Thanks for the reply!
Not that I see, but I'll double check. I got the reinz from rock auto as it was the part they had for the oil pan gasket, and the other I just picked up at O'Reilly's as a back up.
