Our NEW (USED) Blue HHR LS
The pic seems to show that they forgot to A)tighten the hinge bolts and B)forgot to even put the bolt that holds the ball joint in. Or, did the steering knuckle just disintegrate?
Sorry for any confusion you may have - but it just fell apart - Pretty much discinigrated on the road. It wasflat beded to the dealer. Day they delivered it the engine cel came on with onstar diagnostics showing cooling system failure - Long story short evrything has been taken care of. They replaced the thermostat flushed the system, put the service manager in direct charge of all the repairs - All good and I'm happy with the service. Back on the road to enjoy our new HHR!
EASY GOING - LIFE IS SHORT.....
Welcome to the forum
Hope your problems
with your HHR are behind you
The pics of the wheel problem
look familiar except when i had
that happen was on my
2000 S10, It kept breaking
lower ball joints ~
(216)
Hope your problems
lower ball joints ~
(216)
I hope that the dealer at least inspected the other side. I think that I may have demanded 2 new control arms. But, if you are happy.....
better have another trusted mechanic check out the bolts and torque all those nuts and bolts, I just went out and checked my ball joint retaining bolts , never thought they would be loose but they took 1 1/2 turns to tighten up, whew that was close, glad eveybody is ok and your ride is back with you, welcome to the site!!
The 2006 HHR book says:
First pass; 37 lb ft, then reverse NUT 3/4 turn.
Second pass; 37 lb ft + 30 degrees.
If anyone needs the 2006 HHR Service Manual give me a PM.
cj krause
28
May 2, 2006 05:40 PM
