Overheating
Old Mar 14, 2020 | 05:05 PM
Overheated's Avatar
Overheating
I have a 08 HHR SS that started to overheat I started of with the more less costly things like the thermostat, but made no difference. I have to date changed the water pump, timing chain, radiator and fan along with the cap and recovery bottle. All the for mentioned parts were purchased new and all but radiator and fan was done by a mechanic. Does or has anyone else had this problem?
If so was it fixed and how? Or is there any advice on my next step to take.
Oh yeah, I have burped it and not the replaced the head gasket.
Old Mar 14, 2020 | 05:34 PM
Welcome to the site, first off can you please advise which thermostat you used?
You mention the timing chain, did you also replace the balance shaft chain.
Did you flush the heater core and the oil cooler?
also the new rad, what brand and part number.
I need information to determine the problem, so stay with me.
Ah, one more thing , did you use 50/50 mix Dexcool?
Thank you, very much.
Old Mar 14, 2020 | 05:35 PM
What testing has been done? Sounds like you are throwing random parts at it.
Does the fan run when it is supposed to?
How do you know "not the head gasket"?
Old Mar 14, 2020 | 07:35 PM
Overheated how much ? As in what temperature.
Does the fan come on and stay on ? If so, does it cool down with the fan running ? Did you replace the fan with the one that is specific for the SS only ?
The SS fan assembly has a built on control module.
Did you have a loss of coolant when this 1st occurred ?
Old Mar 18, 2020 | 05:59 AM
The OP has since come back but didn't bother to update or answer any of the questions asked.
Looks like another One and Done.
I'm out.
Old Mar 18, 2020 | 10:35 AM
Overheated's Avatar
Answering to op
Answer to op it got to 218 and took about a half hour to get there.
Old Mar 18, 2020 | 11:20 AM
As you can see , the lack of information is very upsetting to some of our members trying to assist you, please take a moment and provide answers to the questions asked, thank you.
It got to 218 degrees and then what happened?
Old Mar 18, 2020 | 05:59 PM
218F is not overheating; 218C is.
At 219F the fan should come on and cool it down to 180F pretty quickly.
Old Mar 18, 2020 | 06:04 PM
We are just at the edge of insanity! But not overheated.
Old Mar 18, 2020 | 06:35 PM
Overheated's Avatar
I've been dealing with a illness and I'm new to this forum and I'm not sure what questions were asked, and as a matter of fact my previous message I sent I was the first time, and took me a minute to figure it out. So offer some suggestions
