Overheating & recent symptoms
It should NOT be coolant coming out of the drain hole-it should be clear water. Catch the liquid in something and look at it and determine what it is.
I don't think a bad heater core would leak out of that drain hole. When i had a bad heater core it leaked onto the inside floor.
1. Is the air conditioner on? 2.What happens when you turn the heater on?
this indicates the heater core or hoses/tubes to it are leaking, the coolant will leak into the HVAC evap drain pan and out the drain tube.
Please have a read prior to changing the heater core...
| Repair Guides | Heater Core | Removal & Installation | AutoZone.com
That hose drains a condensate pan under the condenser coil and the heater core, so it is possible that "something is broken". It is going to cost you a bundle to find out what since they will have to take the dashboard apart to look at it.
It looks like most people think that it is your heater core. Changing it might be a task-but if you have a repair manual it will help(they have step by step instruction). You will have to remove the center console to get to it & also unbolt 2 bolts against the firewall.
I would REALLY MAKE SURE this is the problem before I start taking it apart. Please keep us informed as you progress?
