Overheating & recent symptoms
Old Apr 6, 2015 | 02:25 PM
Ijazzu's Avatar
It should NOT be coolant coming out of the drain hole-it should be clear water. Catch the liquid in something and look at it and determine what it is.
I don't think a bad heater core would leak out of that drain hole. When i had a bad heater core it leaked onto the inside floor.
1. Is the air conditioner on? 2.What happens when you turn the heater on?
this indicates the heater core or hoses/tubes to it are leaking, the coolant will leak into the HVAC evap drain pan and out the drain tube.
Please have a read prior to changing the heater core...
| Repair Guides | Heater Core | Removal & Installation | AutoZone.com
Old Apr 6, 2015 | 02:28 PM
SamuelJ's Avatar
Both the air conditioner and heat work the way that the are supposed to. No changes that I have noticed, anyway.
Old Apr 6, 2015 | 03:34 PM
That hose drains a condensate pan under the condenser coil and the heater core, so it is possible that "something is broken". It is going to cost you a bundle to find out what since they will have to take the dashboard apart to look at it.
Old Apr 6, 2015 | 03:49 PM
Ijazzu's Avatar
It looks like most people think that it is your heater core. Changing it might be a task-but if you have a repair manual it will help(they have step by step instruction). You will have to remove the center console to get to it & also unbolt 2 bolts against the firewall.
I would REALLY MAKE SURE this is the problem before I start taking it apart. Please keep us informed as you progress?
Old Apr 6, 2015 | 04:30 PM
  #26
Heater core.
Old Apr 6, 2015 | 04:32 PM
  #27
SamuelJ's Avatar
Definitely! I'm not expert, for sure, so I'll need to get my hands on a repair manual somehow if I decide to change the heater core myself. Is there a way that I could confirm that it is indeed the heater core?
Old Apr 6, 2015 | 06:05 PM
  #28
Just read the link I posted in #22 there is a verbatim how to change the heater core, so no manual required, oh and you're welcome, thanks for noticing!
Old Apr 6, 2015 | 06:07 PM
  #29
SamuelJ's Avatar
Sorry about that. I'll definitely take a look at it.
Old Apr 6, 2015 | 06:09 PM
  #30
I suppose it could have been overlooked!! I just wanted to ensure you had an idea of what you're up against!
