Oxygen sensor in 2006 2.4
There is an up stream sensor, located before the catalytic converter, either in the pipe after the flex pipe or in the exhaust manifold before the exhaust flange. Then the down stream sensor is just after the catalytic converter in the pipe before the 2 bolt flange .
2006 2.4
2006 2.4
That makes sense. Thanks Now, which one should I get? AC/Delco has many sensors that are all supposed to fit, but they range in price from $55 to over $100. I am at a loss on which to get.
From RA or any other parts supplier, bear in mind there are fakes out there.
https://www.rockauto.com/en/catalog/...2)+sensor,5132
