P Code Confusion
Old Jul 1, 2020 | 04:37 PM
But P0011 is more likely to be a by product of the bad VVT valves. A quick look at the chain won't hurt anything.
Old Jul 1, 2020 | 05:26 PM
That’s why I suggest it, easier to see the chain and the front guide , confirm if there’s a problem or not, if not put the valve cover back on.
Old Aug 5, 2020 | 12:24 PM
Lisa Vaughan Otto's Avatar
Originally Posted by Oldblue
Take off the valve cover, this is enough slack to justify replacing the timing chain, it is an easy job if you have a few tools and some mechanical skills. Cloyes offer great kits and are available through RockAuto, and they offer us a discount.
Order one of these front guide upper replacement bolts.
This was enough slack to trigger P0014 in my 2011 2.4
https://www.chevyhhr.net/forums/www....ad.php?t=60394
https://www.chevyhhr.net/forums/www....ad.php?t=61707
Im just double checking that I can use the Cloyes kit and do not have to buy ACDelco for this part. I keep seeing all the ACDelco only posts so I just wanted to make sure. Thank you
Old Aug 5, 2020 | 12:45 PM
Lonwane's Avatar
I just purchased the Cloyes 94201SAWP kit. Purchased through RockAuto with discount.
It comes with both chains, balance shaft sprockets, crankshaft sprockets,guides and the water pump. $175.00
Don't forget the melling guide bolt.
Old Aug 5, 2020 | 03:02 PM
Cloyes makes ACDelco.
Old Aug 6, 2020 | 08:01 AM
Yes the Cloyes kits are preferred, available in different kits some with cam sprockets some without, depending on your engine and as mentioned with a water pump. We like to advise changing the water pump while the engine is apart for convenience, you’re gonna have dirty hands anyway, might as well do that now!
Old Aug 6, 2020 | 12:16 PM
Thank you all so much!
sciaccio
Oct 21, 2022 05:02 PM
Samantha Ludlow
Oct 15, 2019 05:28 PM
Mark Black
Feb 11, 2018 11:15 AM
tsnell23
Jul 17, 2017 08:33 PM
dkennedy1282
Nov 17, 2014 09:22 AM
