P0010 and P0107 car slow to start...
Old Jan 15, 2020 | 07:40 PM
iluvmud's Avatar
Originally Posted by donbrew
If you replaced one of the VVT valves The other is sure to fail soon. What has happened is somebody replaces one the start the car and the CEL is still on so they assume it is the same problem. I speak from experience. You said That says 1 solenoid.
Most people that have to rely on AutoZone diagnosing end up getting the wrong part; in this case the camshaft position sensors. That is why I asked the question. No offense intended, No need to shout.
Those codes should clear themselves. If you clear the codes it may take 2-3 weeks before all of the OBD2 test are run.
I dont rely on them for parts, I rely on them for error codes. I replaced them both, not offended nor shouting, I just copy/pasted the description and it was that size. All good!
P.S. removed the ground wire and reset everything. Fired the car up and cranked right up and errors are gone, hopefully when the OBD2 test is run I have no issues.
Joelbuddy20
Maintenance and Upkeep
29
Jan 27, 2020 07:57 AM
DASH0071972@
23
Jul 1, 2015 12:31 PM
scrisp
Jun 10, 2015 01:21 AM
randilynn
2.2L Performance Tech
Sep 24, 2014 06:39 AM
