P0019 Code
Old Aug 26, 2014 | 05:18 PM
tmbrenna's Avatar
P0019 Code
I had the code appear a couple of days ago. I first cleaned the Mass air flow sensor. I then went to the auto parts store and had the code pulled. It showed the Camshaft position actuator solenoid as the problem. I replace the part and the check engine light is gone, back to smooth running.
Terry
2010 HHR LT
225,000 miles.
Old Aug 26, 2014 | 05:22 PM
Uh, that's not what P0019 is. P0019 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor B)
Old Aug 26, 2014 | 08:32 PM
Moved from the "How-to" thread on replacing the Camshaft position actuator solenoids to the problem section.
From the code being given, it looks like it is likely that the wrong part was replaced. Those codes can come and go depending on drive cycles and the errors encountered, especially if one disconnects the battery during the procedure of replacing the part.
Sensor = SENSOR
Solenoid = SOLENOID - Big difference.
NxlKing2304
Feb 14, 2014 07:41 AM
RPetersen14
Oct 25, 2013 11:19 PM
edgarfrog
Oct 25, 2013 08:43 AM
LtGhost08
Jun 10, 2013 02:13 PM
tntwolt
Jul 27, 2011 05:53 PM
