P0054 code o2 sensor 2
Old Mar 14, 2018 | 02:36 PM
06REDSEDANDELIVERY's Avatar
I'm guessing it's the O2 sensor behind the cat ? The code came on this morning . It was 20 degrees out and yesterday I drove through a lot of cold snow covered roads..
it's a 2006 early build, ordered in sept. 2.4 engine. automatic, 75k miles. I've replaced the upstream sensor twice since the car was new.
Other than a few things the car has been really great...
Old Mar 14, 2018 | 02:39 PM
Yes that’s the second O2 sensor
https://www.obd-codes.com/p0054
Old Mar 14, 2018 | 04:12 PM
THANKS, other than a few oops'es the car has been great.
This weekend should be 45 to 50 degrees so that is the best shot at replacing it.
I don't know how the car knows it's time for it's yearly inspection, but it always happens just before... dang.
Old Mar 14, 2018 | 04:55 PM
Could be a broken wire.
Old Mar 15, 2018 | 01:54 PM
Ran a tank of high test with 2 bottles of Chevron Tetron, beat the crap out of it, borrowed a friends scanner and removed the code.
It's been off for a day, so far so good. If it comes back I change the sensor.. gas mileage is arround 23. Same as always...
What scanner do you recommend / use .. his cost $200 a few years ago. A little steep for me...
thanks
Old Mar 15, 2018 | 04:57 PM
You just wasted your money and time on Techron. The code has nothing to do with dirty anything. It is about the heater coil in the sensor; it could be bad or the wiring could be faulty or the emissions fuse blew. It indicates an open circuit.
Wrong thread Oldblue?
Old Mar 15, 2018 | 05:45 PM
Thanks got it.
Old Mar 16, 2018 | 05:10 PM
Smile
Checked the wiring this morning early, also sprayed penetrating oil on the sensor (just in case).
Drove 200 miles today, combo of highway and stop and go. Also ran a few errands. Car is running better.
Got 24 mpg as per computer. Since the check engine light is off, I had the car inspected - passed. No codes.
It's starting easier and appears to be running smother.
Refueled with the middle grade gas.
Lets hope the light stays off, at least until summer. ( or until it's warmer)
jojo33
May 20, 2013 12:02 PM
JeramieJJ
Sep 6, 2011 08:25 PM
