P0113 code
Old 03-09-2016, 06:09 PM
Delfuegosr's Avatar
Talking P0113 code
Need help with ECL and engine code P0113. Is this a MAF/Intake temp issue? Just replace the MAF in the intake with a new sensor? Please advise. Thanks! Oh by the way 06 LS with 120k miles.
Delfuegosr is offline
Old 03-09-2016, 06:37 PM
First: are you sure it wasn't P0013?
Second: have changed the air filter recently?
If it is P0113 yes , your MAF is probably bad or,
Everybody has forgotten to re connect the MAF sensor.
http://www.obd-codes.com/p0113
donbrew is offline
Old 03-09-2016, 07:16 PM
Delfuegosr's Avatar
Yeah, P0113 was the code, and thanks for the feed back.
Old 03-09-2016, 07:38 PM
Could be a loose connection or dirty MAF sensor
Oldblue is offline
Old 03-10-2016, 07:55 AM
Delfuegosr's Avatar
I'm going to change the MAF sensor and air filter today, along with some new plugs. Hopefully that will allow me to reset the codes and get the CEL off. Thanks again for the help!
Old 03-10-2016, 09:53 AM
Please not some new plugs, AC Delco 41-103 iridium plugs!
Oldblue is offline
Old 03-10-2016, 10:10 AM
Don't "clear" the codes, let it do it for itself!
donbrew is offline
Old 03-11-2016, 09:04 AM
Grizzly old man's Avatar
If replacing the parts fixes things the codes and CEL will mend themselves, probably in less than 10 drive cycles.
Grizzly old man is offline
Old 03-16-2016, 02:10 PM
Delfuegosr's Avatar
yeah reference code came back after replacing sensor and clearing codes voltage across the IAT sensore is showing -40 DegF with key on and engine not running. Anyone have the Mass Air Flow /Intake Air Temp sensor pin reference voltages and wiring color? Maybe broken wires... hope its not a bad computer
Old 03-16-2016, 03:02 PM
Like this?
If you don't already know: low ref= less than 5V (ground,0V), ref=5V
donbrew is offline
Quick Reply: P0113 code
