P0121 problem
Old Feb 21, 2018 | 03:36 PM
boltfan1953's Avatar
P0121 problem
We have been getting a p0121 code, so we cleaaned the TBS. Got worse, idle went up, so we replaced it and the pedal postion sensor. Same problem, idle at start is at 3-4000rpm,, goes down in drive but when you accelerate goes back up. Any suggestions?
Old Feb 21, 2018 | 05:55 PM
Welcome to the site, P0121 has a relation to the harness rubbing .
As per
https://www.obd-codes.com/p0121
Check the wiring harness for chafing against the bracket under the EVAP valve.
Old Feb 21, 2018 | 10:05 PM
I'd guess at either a broken wire or a bad MAF.
Sounds like The #1 signal wire is not connected somewhere between the TB and the ECM.
Are there any more codes or things you didn't think were relevant?
cllwyrc1
2.4L Performance Tech
11
May 29, 2017 11:52 AM
britishknigth
Jan 31, 2015 07:28 PM
06gray2ltHHR
Aug 1, 2009 10:45 PM
ts5p
Oct 6, 2008 02:47 PM
Black Rose
Dec 7, 2007 11:28 AM
