P0171
Old May 13, 2019 | 09:43 PM
D_larkin's Avatar
P0171
I have been driving my 07 hhr for a little over a year now. I was on my way back from a 200mi drive when the traction control light came on. Got home, warned the wife about it because its really her car. The following day it threw the p0171 code. Running lean bank 1. Now its hard to get started. Once it's going, it sounds normal. Not louder than normal, not running bad, doesnt really sound like it's missing. So i cleaned the maf and that diddnt change it. I also tried to search for intake leaks with a small bottle of propane and a hose, hoping when the intake leak sucked the propane in, i would hear a slight rev in the engine, that had no luck either. So, where should i go from here? Please help..
Old May 13, 2019 | 09:47 PM
Check the flex pipe
https://www.obd-codes.com/p0171
Welcome to the site.
Old May 13, 2019 | 09:54 PM
Check the EVAP purge valve. It may be stuck open.
Old May 13, 2019 | 10:40 PM
D_larkin's Avatar
I checked the flex pipe. I diddnt see any cracks or tears in it, ill go and pull the purge valve off now and see if its stuck open.. Thanks.
Old May 13, 2019 | 11:28 PM
D_larkin's Avatar
Got the evap pulled off and tried to blow ait through it. No air went through so that ones not stuck open. Am i running out of options as far as it being an air problem and time to start thinking fuel system?
Old May 14, 2019 | 07:53 AM
Could be the fuel pump
Old May 14, 2019 | 10:02 AM
DrLoch's Avatar
Did you check the one at the canister to make sure it closes?
Old May 14, 2019 | 02:07 PM
D_larkin's Avatar
Another evap purge?
Old May 14, 2019 | 03:04 PM
DrLoch's Avatar
The one at the canister is the Vent Valve. If it is stuck open it will also make the engine lean when the purge valve is enabled.
Old May 14, 2019 | 06:53 PM
D_larkin's Avatar
Is the white plastic peice by the canister under the car the vent valve? If so, do i just disconnect the 2 lines going to it and try to blow through it to make sure its not stuck open?
