P0234 having trouble problem solving
Old Mar 10, 2013 | 11:28 AM
foolmoon_design's Avatar
Recently set p0234. Turned car off boost is strong and fine. Has only happened twice.
Possible causes: wastgate, vac leak, cracked turbo, dirty t map.
Any clues. I've re tightened all hoses and did the soap test on vac lines. Nothing there.
Old Mar 10, 2013 | 11:51 AM
Did you change to a Forge release valve ?
Old Mar 10, 2013 | 11:57 AM
Nope. Still stock bpv.
I'm leaning towards the turbo solenoid. Or low voltage.
I haven't climbed under car yet, so could be lower tmap wires hitting.
Old Mar 10, 2013 | 12:19 PM
Mine needed the new valve at 30k dealer put new one in. I changed it to the forge, run good ever since. But you are right the lower t map had to be replaced at the same time due to rubbing, thats when they installed the bracket.
terryk
30
Jan 1, 2015 09:26 PM
missbecky
Mar 12, 2012 05:08 PM
Rikki Sixx
Dec 16, 2010 08:16 AM
SSROADSTER
12
May 21, 2010 10:31 PM
FIRETRUCKHHR06
14
Dec 29, 2006 07:07 AM
