Stabilizer Bar Rattle
Old Mar 9, 2013 | 08:26 AM
davemar's Avatar
I have a 06 HHR with 55,000 miles I have had to replace the front stabilizer bars twice due to a annoying rattle and they are again rattling does anyone have a secret to preventing this issue from happening.
Old Mar 9, 2013 | 10:51 AM
BlackknighT's Avatar
Do you mean End Links? Anyway noticed this is your first post.
Welcome to the show!
Old Mar 9, 2013 | 02:17 PM
lpietroforte's Avatar
What is the little round light
Okay, simple question but it stumps me...I have a 2006 HHR and it has a little round light that is always on; it is on the inside roof near the top of the windshield. What is this? Thanks!
Old Mar 9, 2013 | 03:20 PM
Lucky's Avatar
It's what light up the power window switches at night. Put your finger over it and you will see what I mean.
Old Mar 9, 2013 | 03:22 PM
Lucky's Avatar
Need a little more info.
Old Mar 10, 2013 | 02:46 PM
Darryl's Avatar
The stabiliser bar cannot make noises. It is conneced on both sides to the suspension struts by rods, which have flexible joint ends. Those will cause knocking, though not in a short period of time, body roll and understeer when badly worn. Front end noises are also caused by worn steering rod ends.
Old Mar 10, 2013 | 02:56 PM
Ah, but you forget that there are rubber bushings holding the fulcrum points of the sway bar. They do wear out and they do cause noise.
alexrckid
Nov 19, 2014 08:27 PM
Vcode455
Jun 25, 2012 10:41 PM
joeg.satx
Jan 22, 2011 11:54 PM
08blackHHRSS
Dec 8, 2010 12:45 PM
chocolatefonz
10
Nov 25, 2009 09:17 AM
