P0300 p0301 p0302
Old May 3, 2016 | 09:45 AM
Got the flashing CEL again last night, this time it gave me pending codes. It's the same P0300 301 302. So swapping the coil packs did not change the codes. I'll try some new spark plugs and see what happens.
Old May 3, 2016 | 10:30 AM
AC Delco Iridium , spark plugs!
Old May 3, 2016 | 05:47 PM
DrLoch's Avatar
Also make sure to check the gap, while it's been said they are pregapped I've found that the gap was more. If you still have a problem try closing up the gap, try .025-.026 and see if that helps.
Old May 3, 2016 | 06:25 PM
If you touch the whisker it will break!
Old May 4, 2016 | 07:27 AM
DrLoch's Avatar
Forgot to mention that.... yes it will, you have to be very gentile.
Thanks donbrew.
Old May 4, 2016 | 08:54 AM
  #26
Thanks donbrew.
Well, I'm not Jewish, so I am gentile.
Old May 4, 2016 | 09:47 AM
  #27
I'm not Jewish, but I am ..ah.. well, you know, I was born in the 50's in a military hospital, it was automatic. So I'm almost a member of the tribe, but still gentile.
Old May 4, 2016 | 10:03 AM
  #28
DrLoch's Avatar
Gotta love spell check some times
Old May 4, 2016 | 12:16 PM
  #29
Oye voy!
Old May 24, 2016 | 02:10 PM
  #30
After reconfiguring my PVC system to phase 3 of testing, I was on my way to the hardware store when I realized I had forgotten to hook up the MAF sensor wiring. Pulled over and reconnected it, had driven about half a block.
1 or 2 more key cycles (only a mile or 2) I got a solid CEL, P0301 misfire. So I don't know if it's from driving with the MAF disconnected or if it is injectors. I put the new plugs in 300 miles ago.
