P0304 Engine Code
Old Dec 5, 2018 | 10:31 AM
  #51
The next step in your thorough investigation is to remove the head and visually inspect the innards; there is no other testing from outside the engine that will tell you anything.
I am reminded that I have spent thousands of dollars denying a pet had terminal cancer, more times than I am willing to admit. I do understand.
Old Dec 5, 2018 | 10:54 AM
  #52
m_ridzon's Avatar
Originally Posted by DrLoch
FWIW I've seen where the injector seals leaking would cause your issue. You will have to pull the intact to get to those so at that point blast the intake valves which is a know issue on any DI motor.
Thank you. I had wondered this too. Stranger things have happened and I wouldn't be surprised to see it here. I will know better this weekend after I pull the injectors for inspection. I'll apply new seals and re-run the compression test. I'll then drive it a few days to see if the CEL returns on #4.
Also, I have have pistons and rods from an zero mileage LNF that I have on a shelf if you are interested. The rings still have the paint marks on the face.
Are they standard sized bore or oversized? If I rebuild, there is a possibility I will bore the cylinders. Are the domes stock or are they performance?
Old Dec 5, 2018 | 11:42 AM
  #53
DrLoch's Avatar
They are standard bore since they came out of a stock LNF. I replaced the pistons with and rods with forged Wiseco and carillo rods
Old Dec 5, 2018 | 01:55 PM
  #54
The cylinder sleeves aren’t thick enough to be boring out oversized to much.
Old Dec 6, 2018 | 06:58 AM
  #55
m_ridzon's Avatar
Are the sleeves replaceable? Or does the whole block need replaced?
Old Dec 6, 2018 | 07:07 AM
  #56
Cat Man HHR's Avatar
Old Dec 6, 2018 | 07:21 AM
  #57
m_ridzon's Avatar
Awesome! At least if I find that the engine needs rebuilt, I can just replace the sleeves and pistons, rather than worrying about boring it. That makes things a little bit easier. Thanks for the feedback!
Old Dec 6, 2018 | 07:24 AM
  #58
DrLoch's Avatar
Guy can afford the tool but not a decent engine stand????
Old Dec 6, 2018 | 07:28 AM
  #59
m_ridzon's Avatar
I noticed that too!! Hahahahahahaha!!!!!
Old Dec 6, 2018 | 07:43 AM
  #60
I wonder. Do they recommend freezing(shrinking) the liners to make installation easier ?
I remember doing that years ago when replacing the liners in a small diesel engine for a customer.
