P0420
Old Mar 14, 2018 | 07:53 PM
Jmck0020's Avatar
P0420
06 with the 2.2. Engine swapped 3 months ago. Just popped the p0420. Has anyone tried cataclean? Where is the 02 sensor located that I should inspect?
Old Mar 14, 2018 | 08:23 PM
Nothing wrong with the O2 sensors, that means they are working.
was it burning oil and coolant?
You need a new cat, Try eBay less than $200.
Old Mar 15, 2018 | 07:37 AM
X2 not the O2 sensors, a cooked catalytic converter.
Old Mar 15, 2018 | 06:58 PM
Jmck0020's Avatar
I replaced a cat a few years ago are there 2 of them?
its not burning oil or coolant.
Old Mar 15, 2018 | 08:17 PM
Why did you change engines?
Only 1 cat on a 2006, why did you replace it?
Old Mar 15, 2018 | 08:47 PM
Jmck0020's Avatar
It got noisy, i never had this code before, I had a repair shop replace, I took the original to the scrap yard
Old Mar 15, 2018 | 09:02 PM
Jmck0020's Avatar
a connecting rod broke and punched a hole in the side of the block. 179000 mikes I changed the oil, every 3000 or so with synthetic since it was new. I think I drove it too hard lol
Old Mar 15, 2018 | 10:14 PM
Well, rods don't usually get thrown when the sump is full of oil. I am guessing a lot of oil got burned in a short time. That kills catalytic converters.
Catalytic converters don't make noise when they fail, they throw p0420 codes.
It is not unusual for replacement cats to be of inferior quality.
Old Mar 15, 2018 | 10:16 PM
Jmck0020's Avatar
Ok thanks
Old Mar 16, 2018 | 06:41 AM
solman98's Avatar
You can replace the entire down pipe assembly with cat for under $200 off ebay. Very easy swap.
donbrew
Jun 6, 2020 02:44 PM
Happy13178
Dec 29, 2014 09:08 AM
NxlKing2304
Feb 14, 2014 07:41 AM
NxlKing2304
Jan 24, 2014 11:34 AM
CarlsSS
Oct 4, 2010 10:09 PM
