p1174 -Fuel Trim Cylinder Balance
Old Apr 18, 2015 | 08:36 AM
  #41
Originally Posted by novadude
oops, what did i miss ?
The part about going advanced and clicking the insert icon then pasting the link into the dialog.
Or you can do what you did, then edit the post, replacing the "url" wrapping with "IMG".
Old Apr 18, 2015 | 09:09 AM
  #42
novadude's Avatar
my apologies, ahhh, I copy/pasted the "http" code,
FYI, now i have probably fouled up my downstream 02 sensor with all the oil,
now i have a P0420,, time to park the hhr until i can get to fixing it,
went and got my 2nd vehicle legal to drive,
I will try the seafoam in a few days, more to come
Old Apr 18, 2015 | 02:24 PM
  #43
All that oil would "foul" the cat not the sensors.
Read the link in my sig: https://www.chevyhhr.net/forums/how-...e-light-52828/
Old Jan 8, 2019 | 12:04 PM
  #44
hurst2001's Avatar
Originally Posted by SmootHHR
Well, didn't need a coil pack. Changed the #4 plug and the misfire hasn't returned..nor has the p1174. I am, however, still getting the p0172 from time to time. Wish I could pin point what was wrong as that friggin light makes me crazy!
hey smooth how’s it workin for you ? I got the same thing but only p1174 going to change plugs clean maf and throttle body and have it scanned ..
Old Jan 8, 2019 | 01:53 PM
  #45
SmootHHR hasn't logged onto the site since Aug. 2015. This thread was started almost 7 years ago in 2012. Doubt you'll get a reply from him.
Best to check some dates and log ins before looking for an answer from a long gone member.
Old Jan 9, 2019 | 12:12 PM
  #46
hurst2001's Avatar
my bad but here’s my update had new plugs in clean the maf and throttle body .. well the clamp to hose that goes to the throttle body was busted causing air to get in there to throw the code ... and fuel injector on 3 cylinder is dirty causing a very slight mid fire .. it was put on a scanner so I’m going to run some Techron and 93 octane and see if it clear up ... if not going to change it when the weather gets better .. thanks to everyone help ...
jdevries
Jan 24, 2014 06:25 PM
PaperChaseHHR
2.2L Performance Tech
Oct 10, 2013 09:26 AM
rotaryboy23
Sep 6, 2010 10:54 AM
robotworkshop
2.0L Performance Tech
Sep 12, 2008 05:39 PM
