P2270
Old Aug 29, 2019 | 05:45 PM
Insulin_addict's Avatar
P2270
I get this code (p2270) after replacing the downstream o2 sensor. Mechanic says everything is within of what Chevy recommends. Is there a chance that it’s the wrong o2 sensor or could it be a defective sensor?I got it from Advance Auto and am not sure if it’s a OEM sensor. No evidence of cracked flex pipe or any other exhaust issues. Anything else I should look for? Need it to pass emissions!!
Old Aug 29, 2019 | 05:55 PM
Bosch brand?
The code is telling you that the O2 Sensor is not capable of reading high enough.
Why did you replace the sensor to begin with? They rarely break.
Old Aug 29, 2019 | 05:56 PM
Of course there is a chance it is the wrong sensor or defective. All things are possible.
Posting a link to the Advance auto part would help checking that out.
Check this for some good explanations and things to check:
https://www.obd-codes.com/p2270
Old Aug 29, 2019 | 06:58 PM
Is it any of these
https://www.rockauto.com/en/catalog/...2)+sensor,5132
Old Aug 29, 2019 | 07:39 PM
I replaced it because I had a code that said it was not operating correctly. Don’t remember the exact code. I am not sure if it is a Bosh sensor. I threw the box away. I am going to go to Advance and see if they can pull up which one I bought. I am going to replace with OEM sensor.
Old Aug 29, 2019 | 07:45 PM
NGK/NTK they make the ACDelco.
Or, it was operating correctly and finding a fault? Don't ever try to translate the title of an OBD2 test, you will be wrong 98% of the time.
Old Aug 29, 2019 | 07:50 PM
Probably the latter. This is where I am now, guess I just need to replace sensor with NGK/NTK.
Old Aug 30, 2019 | 08:57 AM
Called advanced and they said that it is a denso sensor and that it was the correct part number. Is denso OEM, or should I stick with the AC Delco?
Old Aug 30, 2019 | 12:36 PM
AC Delco
Old Aug 30, 2019 | 01:18 PM
Post #6
