Panel lights issue
Old May 11, 2024 | 02:24 PM
Splice is probably wrong not bad.
Did you splice into the wire from the e-brake switch (light blue) that sends a ground signal? That should not connect to any lights.
What does the radio install book say to do?
Old May 11, 2024 | 02:46 PM
How is the brake light signal used by the radio?
Old May 11, 2024 | 04:04 PM
Falequin's Avatar
I did yes, it was the light blue wire for the e-brake switch. The radio responds properly to the e-brake getting set and reset.
Falequin's Avatar
It's used basically for playing some games while the car is parked, nothing necessary really.
Old May 11, 2024 | 04:12 PM
So. The radio only works when the E brake is on ? What’s the point in wiring it that way ?
Old May 11, 2024 | 04:21 PM
It is supposed to make it so the driver can only watch vids when parked. Most people use a go around.
Old May 11, 2024 | 04:32 PM
Falequin's Avatar
No that's very wrong. The radio works. The only reason for the E-brake wiring is that there are features, such as games that are in the radio, or in other ocassions Android mirroring, that are only enabled when parked. The rest of the radio works as you're driving. So your basic stations, android auto, podcasts and all the standard stuff works just fine. I just mentioned the E-brake splicing thing because it's something that I did when I lost the lights. I'm not sure if this is the cause or not. I'm just trying to pick people's brains here to see there's something I might've done to cause this when I spliced the parking brake signal to the radio. Or what the other causes might be. From the latest schematic that I posted, I measured the voltage on that SWC 2A fuse and didn't get any voltage from it. I suspect that i'm not getting anything from that PNL LAMPS SW SIG, but I'm at a loss at this point.
Old May 11, 2024 | 04:57 PM
Have you slapped your forehead and turned the dimmer wheel?
Old May 11, 2024 | 04:59 PM
greg8453's Avatar
Originally Posted by Falequin
The potentiometer is good I believe. I put a new one in hoping that was it but nothing happened.
You need to get an understanding of what happens with electronics. These are very simple to verify. Open and close the two wires and see what happens.
I'm not sure you tested anything correctly. Here's the fastest easiest way to test fuses using a meter or test light.
Old May 11, 2024 | 05:24 PM
Falequin's Avatar
There was no need for this...
