Panel lights won't dim
The dimmer is a potentiometer. IDK how the dimmer is wired to the rest of your electronics but if it is putting out a resistance that falls out of spec or is shorted I could see that causing other problems.
Not sure that it's a potentiometer per se in these cars. The instrument lamps dimming control is located in the BCM. The control on the dash is more likely just a position sensor the feeds a signal to the control in the BCM.
Too much truth in what you speak.
I'll look into the battery. And you are correct; the batteries usually just die. You might park for a minute, come out and a cell is open.
I was also thinking a ground-related problem, but with so many points to check...
If I do disconnect the battery, I wonder if the car will have to re-learn the transmission parameters. https://www.chevyhhr.net/forums/show...t=call+surging I don't want to have to go through this again.
