Panel rear door/liftgate issue
Old Jul 2, 2018 | 08:50 AM
jpplumbing's Avatar
Hey guys, I have a problem with the rear door pop and liftgate. Nothing is working. I checked the fuse and its fine. Not sure on where i should start looking. I also swapped out the relay for it with another one and that didnt do anything.. Also i can not gain access to the back of the liftgate to open it manual since it has custom shelving that i can not remove from the back area.
Old Jul 2, 2018 | 09:38 AM
If you have a second remote, did you try that?
Old Jul 2, 2018 | 10:08 AM
Sounds like the touch pad went bad.
If you have a really good scanner there are B codes that can help diagnose. If the battery is below 9 V it won't work.
A scantool like a Tech2 can get data from the switches and relays.
This isn't much help, but it's all I got.
Old Jul 2, 2018 | 11:24 AM
You may want to look at the thread below. Sounds like a similar problem and there's some good info posted.
https://www.chevyhhr.net/forums/prob...em-help-59738/
DwRed2LT
Jun 26, 2016 03:41 PM
outlandishhhr
Jan 11, 2008 08:37 AM
