Pins/connectors needed for pcm?
Old Jan 29, 2025 | 01:24 PM
lazaino's Avatar
The 68 pin connector shown in the first picture comes without pins, you crimp pins to the wires and then insert the pins into the connector. They can be removed with the proper tool or sometimes with a suitably sized sewing needle. If you want pins, probably better if I crimp 8" of 20ga wire to the pins so you can just splice into the existing wire as very few people have the proper crimping tool.
Old Jan 29, 2025 | 07:42 PM
The TSB is pretty simple; remove the connector and inspect the pins, sometimes they get loose, bent or pushed out the back of the connector.
SwissHHR
Jul 29, 2014 01:36 PM
lasater
Jan 4, 2013 05:55 AM
Telepsychic
Maintenance and Upkeep
Feb 26, 2011 03:55 PM
ShelbyVegas
Apr 16, 2010 04:58 AM
DrLoch
2.0L Performance Tech
17
Jan 22, 2009 09:38 AM
