Pissed!!! HHR Key Stuck - Shifter Micro Switch / GM denying responsibility
Old Apr 19, 2010 | 11:52 AM
  #41
Sno White's Avatar
Originally Posted by thedonn007
I would not recommend that. It does not sound like a good idea to always have that switch in the depressed position. Your car will think that it is in park while you are driving.
What will happen if he is able to permanently depress that button or better yet find the leads to the solenoid and activate it electronically is to enable the key to be withdrawn while the vehicle is in motion, locking the steering wheel. This safety feature was put into all our vehicles when an irate passenger reached over and took the keys out of the ignition causing the driver to loose control of the vehicle.
Old Apr 20, 2010 | 06:30 PM
  #42
ChevyM84's Avatar
i still have to push the button and apply the brakes to shift gears....
Old Apr 20, 2010 | 06:32 PM
  #43
ChevyM84's Avatar
i probly dont need to do it but i just cant see paying $160 for a part thats gona break again....
Old Apr 22, 2010 | 02:37 PM
  #44
tylertaylor's Avatar
same thing went wrong with my hhr 07 im using the relase under the wheel rite now ...what shuld I do?
Old Apr 23, 2010 | 08:43 AM
  #45
Doc brown's Avatar
I just replace mine. For a time, I popped the cover off the steering column to allow the manual release until I had time to fix the problem. The next day, the shifter button collapsed. I toyed with taking it to the dealer and fighting to get it covered under warranty, but I weighed out the time and aggravation involved vs. cost of the part and time to install (a little over an hour). I opted to do it myself. I have ordered many parts from http://www.gmotors.com/ for my Cadillac in the past and have been very pleased. The shifter was $116 including shipping. They shipped the same day as I ordered. I had it in less than a week. This is the genuine GM part (gmotors is Palm Chevrolet in Gainsville, FL). I will post the part # later.
I wanted to take pictures of the procedure but time has been a premium of late, I was also in the middle of installing a floor in our living room. wrusprod has enough photos to get someone started, see this thread: https://www.chevyhhr.net/forums/problems-service-repairs-42/ignition-jamming-3947/. A couple of things to note if you choose to do this on your own: You must take off the plastic "skirt" that wraps around the base of the shifter. This is to get at the bolts and plug on the left rear of the shifter. I have a dash kit, so my shift plate has a cover on it. Removing the shift lever is a bit of a pain, but doable. As some have said in other threads, you turn the chrome cover and move it down to expose the set screw. But I had to use a screw driver to pry down the cover on both the old and new shifters. The set screw on the old shifter was "american", the new one was metric. Go figure.
For those who are concerned about getting the same part, the new one has a different setup. The old one had only plastic rods holding the pin. Over time the plastic wears from the pressure and the rod falls out. Yes, you can push it back in and probably glue it. But it will come out again. Mine was so worn that it wouldn't stay in place at all. The new shifter (different part #) has metal rods holding the pin.
Old Apr 26, 2010 | 06:40 AM
  #46
thedonn007's Avatar
I wanted to take pictures of the procedure but time has been a premium of late, I was also in the middle of installing a floor in our living room. wrusprod has enough photos to get someone started, see this thread: https://www.chevyhhr.net/forums/showthread.php?t=3947. A couple of things to note if you choose to do this on your own: You must take off the plastic "skirt" that wraps around the base of the shifter. This is to get at the bolts and plug on the left rear of the shifter. I have a dash kit, so my shift plate has a cover on it. Removing the shift lever is a bit of a pain, but doable. As some have said in other threads, you turn the chrome cover and move it down to expose the set screw. But I had to use a screw driver to pry down the cover on both the old and new shifters. The set screw on the old shifter was "american", the new one was metric. Go figure.
For those who are concerned about getting the same part, the new one has a different setup. The old one had only plastic rods holding the pin. Over time the plastic wears from the pressure and the rod falls out. Yes, you can push it back in and probably glue it. But it will come out again. Mine was so worn that it wouldn't stay in play at all. The new shifter (different part #) has metal rods holding the pin.
So you installed the new shifter then? Any fitment issues?
Old Apr 26, 2010 | 08:24 AM
  #47
Doc brown's Avatar
No issues. Its a GM part, not aftermarket.
Old Apr 26, 2010 | 07:28 PM
  #48
ChevyM84's Avatar
i bought a new shifter(as mine was torn up with all the driving i do) but i glued the rod in the shifter and it works....but dunno how long
Old Apr 26, 2010 | 07:32 PM
  #49
ChevyM84's Avatar
i also glued the actuator(whatever its called)
Old Apr 26, 2010 | 08:35 PM
  #50
Question
how do you take the shifter off to glue the pin in?
