Plastic Cover and brackets on fuel lines
Old Feb 11, 2019 | 11:51 AM
092lt's Avatar
I am having an issue removing the plastic cover over the fuel lines and the brackets/clips holding them in. They will not come off and the lines are rotten underneath. I've searched and can't find any insight and I'm about to permanently delete them if I can't figure I out I would really appreciate any help
Old Feb 11, 2019 | 05:01 PM
You simply, gently pry the clips with a screw driver or a trim tool. New clips and that retaining piece are available still , I just used nylon tywraps to secure them after after I installed the new fuel and vapour lines
Old Feb 11, 2019 | 05:20 PM
092lt's Avatar
I ended up getting the 2 off that are attached to the floor pan but the long one broke
Old Feb 11, 2019 | 05:37 PM
https://www.chevyhhr.net/forums/prob...y-clips-60557/
part numbers are in here
Our go to guy for used parts Hellshotrod has used ones send him a PM
Old Feb 11, 2019 | 06:02 PM
092lt's Avatar
Thank goodness those ones were ok. This long one here I have to find
Old Feb 11, 2019 | 07:32 PM
That’s the one I tywrapped to hold it tight.
Send hellshotrod a PM
budzone
May 16, 2018 10:30 PM
powell100
Feb 6, 2018 07:59 AM
porter2017
Nov 7, 2017 03:06 PM
cwest84
Feb 20, 2015 07:53 AM
