Please help. A conspiracy theory that the Chevy HHR is out to get me . Help. 911
Old Jul 7, 2025 | 11:20 AM
ThisIsHHRd's Avatar
Originally Posted by donbrew
Well, misfires will cause the failure. Along with some other things.
Did the CEL flash? That means "STOP AND REPAIR NOW OR THE CAT WILL DIE".
no, the CEO did not flash we’re talking about the little device that I read the thing off of right
Old Jul 7, 2025 | 11:21 AM
ThisIsHHRd's Avatar
P0751 Shift Solenoid A Performance / Stuck Off
P0420 usually a bad catalytic converter
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0700 lights the CEL, to alert you to the P0751 issue
P0751 duplicate
The transmission problem could be causing the noise. The cat and/or the evap could be causing the performance issues.
honestly, if you guys were me in my situation, knowing what you know, where would you start the EAP system leak has been there and it has caused no problems so I’m really thinking that it’s the catalytic converter then because that’s the newest code that and the misfire
Old Jul 7, 2025 | 11:30 AM
"Caused no problems" yes it did, it killed the cat.
The CheckEngineLight is the light on your dashboard that looks like an engine.
Old Jul 7, 2025 | 11:32 AM
ThisIsHHRd's Avatar
"Caused no problems" yes it did it, killed the cat.
Nobody knows how to repair an Evap system when I called around I just accept it’s broken. I can save up to fix it. I just got a 700$ quote on catalyst. It’ll take me a couple days but I can do that. Where should I start. The check engine light is not flashing and now I have to drive From Cleveland to Detroit. Pray for me.
Old Jul 7, 2025 | 11:35 AM
Start with testing the evap vent valve, see if you can blow air thru it, it should be closed.
This one up under the hood if you can blow air thru it , it needs to be replaced
Old Jul 7, 2025 | 11:36 AM
ThisIsHHRd's Avatar
I know u guys care cuz u are here helping me. I feel so useless and stupid. I’m a literal homeless SW trying to just stay alive another day. I’m sorry that I’ve let the check engine light stay on for so long. Some days it’s a matter of gas or food. Other days I get to enjoy nice things because some random rich man paid for it. But these men want me to be stuck around them they won’t fix my car but they will buy me named brand lingerie.. if u give me advice because u know what ur talking about im going to trust you and actually use your advice to become a better person and a better hhr owner. I have spent days and hours maybe even weeks worth of tears have fallen in this car. I just need her to last a couple more months. If she dies I literally lose everything.
Old Jul 7, 2025 | 11:37 AM
ThisIsHHRd's Avatar
I personally replaced this 6 months ago. Should I take it off and try it again? I am capable of doing this. This is a great place to start.
A replacement cat, is 5 fasteners
https://mufflerexpress.ca/products/c...-2-2l-and-2-4l
Old Jul 7, 2025 | 11:40 AM
ThisIsHHRd's Avatar
am I capable of doing this myself? I can afford the part. I’ll bloody my soft hands. I will suffer under this car cause I’m willing to put my blood sweat and tears into this. I need to help myself. I need this car to last. I have faith in myself and if you tell me that I’m capable of doing this and I don’t have to weld or use a jigsaw or cut metal that I know I can do this. So tell me what u think and I’ll order this part.
Old Jul 7, 2025 | 11:52 AM
I thought the vent valve was back by the fuel tank?
Could this p0449 be a blown fuse?
Donbrew has a link to free shop manuals, in his signature.
