Please help!!!!! If anyone can.
Old Nov 17, 2017 | 04:21 AM
harly14's Avatar
Angry Please help!!!!! If anyone can.
Tc light and engine light missfire#4 I have done all this 4 new plugs all new coil packs new air filter mass air flow sensor exhaust and intake Selinoids Then drove it 240 miles tc light came on first then check engine engine light. Help I’ve just about had it 2006 with 65000 mile on it. I was gthinking camshaft sensor next.
Old Nov 17, 2017 | 06:45 AM
Welcome to the site, what is the code for the check engine light?
Old Nov 17, 2017 | 08:01 AM
Like OB suggested, head down to your local chain auto parts store, where they will read the OBD2 codes for you. You could have saved a lot of money if you had done that first.
I'm in Cali, where they won't read them for you anymore, so I bought a reader.
Old Nov 17, 2017 | 08:12 AM
Compression and leak down.
Which engine?
Old Nov 17, 2017 | 08:37 AM
Says they replaced the "selinoids", so I'm guessing it's the 2.4l.
Old Nov 17, 2017 | 08:40 AM
harly14's Avatar
The scanner just said missfire#4
Old Nov 17, 2017 | 08:47 AM
No it didn't! It may have displayed a code like P0304, and added a description like "misfire #4". What we are asking for is the number.
Are you noticing a loss of coolant?
Old Nov 17, 2017 | 09:01 AM
Then I suggest you inspect the harness for the coil and injector for #4
Old Nov 17, 2017 | 09:10 AM
harly14's Avatar
P0304
Old Nov 17, 2017 | 10:37 AM
Things needed for diagnosis:
Compression and leakdown test
fuel pressure test
inspect for loss of coolant
inspect wiring and connections to #4 spark plug/coil
have battery tested
