Please help!!!!! If anyone can.
Old Nov 17, 2017 | 01:34 PM
Could be a failing catalytic converter, also
https://www.obd-codes.com/p0304
Old Nov 17, 2017 | 05:02 PM
harly14's Avatar
Getting rid of it 150 in all 3 and 120 in #4
Old Nov 17, 2017 | 05:17 PM
Head gasket. a shop could fix for 6 hours labor + $50 for the gasket.
Old Nov 17, 2017 | 07:10 PM
It could be a stuck or carboned ring, run Seafoam thru it, can’t hurt.
Old Nov 17, 2017 | 07:22 PM
It could be a few things. The previously mentioned leak down test would determine whether it is rings/piston, gasket, or valves.
Old Nov 18, 2017 | 12:25 PM
db2006's Avatar
Did you try putting oil in number 4? If it hasn't been firing the rings might be washed down by the unburned fuel.
Chrisbaran444
Dec 22, 2015 01:22 AM
2smokey
13
Aug 23, 2012 12:18 AM
IndyRetroGal
29
Aug 29, 2008 10:49 PM
itschaboykenny
Nov 15, 2007 11:01 PM
upzaw2000
Jan 30, 2007 01:32 AM
