Please Help Wet Floorboards
I just fixed mine it was leaking from the sunroof drain If you pop the cover loose at the top of the A piller there is one torx screw cant remember the size and then pull the sun visor down 3 screws you can look in and see if the drain lines are hooked up in the front corners of the sunroof Im not sure if there are rear drains or not
The 06's and 07's had the cowl leak but they fixed the design in 08 .
Might be a bad seal around the door. Not sure about the wiring harness on the 08's. I had heard about it on others.
Your best bet would be the dealer before the warranty is gone. Once they have it noted in there system you will be covered for awhile in case it leaks again.
Check post 21 in this Thread https://www.chevyhhr.net/forums/show...t=18093&page=3 Maybe ChevyMrg will reply if he is on or tomorrow with suggestion. He is usually pretty helpful
THANK YOU !!! and ?
thank you , so much , i will check that in the mourning. were your drivers side floorboards wet , front and back ? i'm just checking because i have found that some years are different. like i wrote earlier about under the cowl being different on the 06 than on the 08.
THANKS and ?
thanks to all , and thanks so much to chevymgr for all the info. i still have not made it to the dealer. could someone please tell me if there is a # , and what is that # that i can register this problem with gm , so that i will be covered ? if i can't make it to the dealer tommorow , i'll be over 36000, maybe sooner if i have a problem on my route. thanks again to all , i have done alot of reading on this site, in fact i have never left it since i found it a few days ago.
gm was no help
i just called the gm customer assistance , and explained my situation. i was told that as soon as the vehicle reaches 36000 , i would be charged a diagnostic fee, and was also told that my wet floorboards may not be caused by a defect. wow , this is a tough world , sometimes makes me want to go back to drinkin and pimpin. i often believe that it just wasn't meant for me to ever have anything nice.
