Po107, Co561-71...have scan-tool, should I use it to clear codes?
codes
Chevrolet Enhanced codes: #1=MIL P0449 (evap emission vent solenoid valve control circuit), #2=FSC DTC P0446 (evap emission vent system performance), #3=FSC DTC P0449 (evap emission vent solenoid valve control circuit), #4=HISTORY P0449 (evap emission vent solenoid valve control circuit) I've looked at many code links, and watched South Main Auto videos concerning these codes. I'm hoping that I didn't blow the circuit with my tesing, with and without the solenoid plugged in. I might've crossed my probes with battery voltage going to the control wire. Wouldn't the fuse protect the circuit?
Did I offend? Sorry, if so. I guess I'm back to square one, and must replace the vent valve solenoid (whether or not it tested good) with a new one, to be able to know whether the PCM is still sending/receiving signals to/from it. Really worried that the PCM might be damaged by my testing (when I crossed probes). I would be able to see that on Torque Pro (my scan-tool doesn't), but my bluetooth dongle ceased communicating with my phone. I'm buying another dongle. After that, I just don't know....Thanks for the offered help, so far.
new wrinkle to persistent problems...
I continued my testing using TORQUE PRO, and OBD LINK (new app, since I replaced my sometimes erratic BAFX dongle- though very reliable 'til just lately- with the OBDlink LX dongle); the O2 test completed, and I only needed to solve the evap test problem remaining. I ordered a new evap vent valve and jumper from Amazon (ordered twice, first shipment never arrived), and after installing it, the dtc's vanished. So, I restarted drive cycle testing. Now, with limited mileage, all tests are completed (according to the scantool, and Torque and OBDlink apps- the apps also show live data of the O2 sensors and evap systems working fine-except the O2 and evap. I had to stop to refuel (tests must be run between 3/4 and 1/4 tank full). When I started the panel after filling, and put it in reverse, my DIC displayed service engine, service traction, TPMS, etc. I shut off the engine, restarted, and the DIC was clear. I returned home, with the Torque app still running. Now both apps and the scantool show o2 an evap tests not complete, and no dtc's present. However, the 3100i scantool shows (in Chevrolet Enhanced Codes, only):
The fancier the scanner the more likely you get "phantom" DTCs.
The CEL went away when I restarted the engine; I didn't clear any codes, nor disconnected power. The phantom codes never appeared on Torque or OBDlink apps, only on the Innova 3100i (a mid-range scantool, $79 on Amazon), after I returned home.
As long as there is no CEL and no current codes you should be OK.
Those mfg specific codes are not reliable since they may be for Chevrolet, but Impala not all Chevrolet. Basically, ignore them unless they seem to be causing the problem. I don't think many of them actually apply to HHR. Yours may mean that you used the cruise control then turned it off by stepping on the brake,
or the connector to the TCM is faulty.
" put it in reverse, my DIC displayed service engine, service traction, TPMS, etc." makes me wonder about a loose wire under the hood.
O2 test now complete, but forgot to check for ABS dtc's
I forgot to check the scantool for ABS codes yesterday. It had two:
