Is it possible to reverse the VVT sprockets?
Code p0303, dead #3 cylinder
I have edited this post and title to reflect the real problem on this 2006 HHR with a 2.4. Cylinder #3 is not firing, followed by a code.
Well, now, I'm not sure... They seem to be the same part on the 2008-2010 2.0 SS.
But they may be different on the 2006 2.4
Part Number: 12621505
Supersession(s): 125785162.0 LITER. 2.4 LITER. Exhaust valve. ASSEMBLY - CM/SHF POSN. GEAR.
Part Number: 12578515
2.0 LITER. 2.4 LITER. Cam position. ASSEMBLY - INTERIOR. GEAR. Position. Sprocket. Variable (VVT) Adjuster.
2.0 LITER, cam position. 2.0 LITER, intake. 2.4 LITER, cam position. 2.4 LITER, intake. Aura Green Line, Aura; Intake. Aura; Intake. Cam position. Cobalt; 2.0L, 2.4L; Intake. Equinox, Terrain; Intake. G5; 2.4L; Intake. G6; Intake. HHR; 2.4L; Intake. HHR; Intake.
ZZP shows different part numbers also.
https://zzperformance.com/products/cam-phasers
Okay, here is why I am asking. Perhaps if I tell the full story it may help.
I bought a 2006 HHR with a timing chain guide broken. I never had the liberty of hearing this car run, I basically picked it up on a note because the owner did not want to deal with it. The shop he had it at said the valves were bent.
When I towed it home I removed the head. To my surprise the valves seemed ok, but I sent it off to a machine shop anyway to get a second opinion. Well these idiots just decided to do a valve job on it without consulting me, but said no valves were bent.
When I was preparing the head for reassembly, I took notice that they wrote in black marker on the VVT sprockets “intake” and “exhaust”, but they were reversed. I figured they just mixed them up when they put them back on, so I reversed them to their proper sides.
Well, I am having some issues with the way it runs, periodically the T/S light comes on and when it does there is some sort of roar coming from the motor. Googling my symptoms brought me here, and I saw a few references to the variable cam modules going bad which could cause the issue.
Then I had an evil thought,,,,,, what if they just wrote the wrong sides on the sprockets and then I actually reversed them thinking I was correcting the issue.
This problem comes and goes, it is not constant. No check engine light, only the T/S light. Then I shut the car off its fine for awhile the next time I drive it
Got a set on order. They were cheap enough to replace even for just general maintenance/age. Of course not if I bought them locally, a pair for over $100 but on Amazon less than 1/3 that (all with 5 stars)
