Power Driver Seat
Old Aug 20, 2017 | 12:50 PM
DanH's Avatar
Power Driver Seat
So my seat won't move forward anymore, it still goes up and down and I hear the motor click on when I go to move the seat backwards. I already replaced the fuse on the off chance that might have had something to do with it. The wire connections that I could see looked okay, any ideas?
Old Aug 20, 2017 | 01:10 PM
Something jammed in the rails/track/thingy that the seat moves on....
Old Aug 20, 2017 | 01:11 PM
Did you check for relays?
Anything obstructing the travel?
Old Aug 20, 2017 | 01:41 PM
DanH's Avatar
I'll have to look, it's hard to get my fat head under there. Thing is when I push the button to move forward I don't hear the motor try at all.
Old Aug 20, 2017 | 02:34 PM
You can take out the 2 rear seat mount bolts. This will allow you to lean the entire seat forward and see the mechanical workings under there.
Sounds as if you may have something obstructing the track, a broken track part or a weak, bad F/R motor.
smileyfrowned
Jul 9, 2019 07:44 AM
TAK
0
May 10, 2012 07:53 PM
JJ_HHR
Apr 30, 2008 09:13 PM
da_dad66
2.2L Performance Tech
0
Apr 8, 2008 08:03 PM
Juli
Aug 7, 2006 04:28 PM
