Power steering, check engine, traction control, no speedo, remote start not working,o
Old Nov 28, 2011 | 09:03 PM
RBradley's Avatar
On my 2006 the problem turned out to be a connection on the lower passenger side near the fuse panel. There is a group of wires there and they were pulling loose, especially when cold outside and things were a little rigid. When the problem finally worsened to the point that it happened in the middle of driving instead of just at startup I removed the lower waterfall panel and tugged at the group of wires, the engine sound immediately changed and everything went back to normal. I used my OBD tool to record any codes and reset it. The problem has not recurred since that incident in March/April. Obviously I didn't find the exact source wire and it may come back this winter but my fingers are crossed.
Old Nov 29, 2011 | 12:56 PM
ImNewHere's Avatar
I will look there. My mom had a 2006 HHR that had the same problem and left them stranded, but the dealer performing the warranty work on it replaced components. When mine did this in February the dealer only cleaned connections under warranty rather than replacing the components. It's frustrating that it is back.
I took the connections loose in the battery compartment and cleaned them all and then put them back, and it fixed it last night, but after 2 minutes of running the problem was back this morning. This time it was the traction control light, flat lines on all but the coolant temp, oil life, and the mileage on the vehicle, and hard shifting. I also heard a clicking when I hit the brakes, something that sounded like a relay clicking in and out, and the auto door lock function did not work. Also the info center said POWER STEERING and the speedometer did not work. Occasionally the speedometer would come on and POWER STEERING would go out, then it was back to the way it was. There was no check engine light on. I was able to retreive no codes.
This is frustrating that it was not actually fixed when it was under warranty. Now I need to figure out what to do myself.
*edit: I was able to get code U0101 and P0700 out of it. Then about 10 minutes later everything came back and worked normally other than the CEL is still on.
Old Dec 22, 2011 | 08:05 PM
ImNewHere's Avatar
I found the TSB on it, removed and reseated the connector it addressed, and no more problems for the past 3 weeks.
Old Dec 22, 2011 | 08:33 PM
Old Dec 24, 2011 | 12:20 PM
panel express's Avatar
Hi , have same prob. cant find the TSB you found , a little help , Thanks
Old Dec 24, 2011 | 05:18 PM
ImNewHere's Avatar
https://www.chevyhhr.net/forums/show...&postcount=104
Old Dec 24, 2011 | 07:05 PM
Hi , I dont have on-star, Thanks for the Help .
Old Dec 24, 2011 | 07:29 PM
ImNewHere's Avatar
Did you try unhooking the battery? I would do that, then see if any of the plugs into the control module are loose, and maybe reseat them. Then maybe leave the battery unhooked for a half hour. I would also pump the brakes multiple times so you discharge any residual voltage. Try that and see if it works. I know on older stuff I've had it work.
Old Dec 24, 2011 | 07:42 PM
Hi , I had the Batt. cable off for a 1/2 hour but didnt think of pumping the brakes I'll give it a try ,and just so I'm straight on this one where would you say the Control Module is ,,LOL. Thanks
Old Dec 24, 2011 | 08:01 PM
ImNewHere's Avatar
Right behind the panel on the passenger side of the console/waterfall area. It's about where the passenger's left foot would hit. The panel pops off pretty easily.
