Power steering still stiff
I recently purchased a 2011 HHR LT 2.2. I was told the power steering assist motor was out so I bought a new one and replaced it. I noticed the steering is better and more stable but still by no means easy to turn. The previous owner did put in a new intermediate shaft and lower control arms. The steering wheel center is also severely off, center is at about 4 o’clock right now. I was told that having a tech hook up a code reader could fix the power steering issue. Also after having new tires installed the esc keeps randomly activating as I drive. Mostly in turns or if I hit a bump. Another issue I have is that when I start the car the steering wheel spins all the way to the left until it hits the bump stop. When it hits the bump stop I give the wheel a slight nudge and it frees up staying in that fully turned to the left position. I appreciate any direction anyone can give me. Thank you.
Welcome, the intermediate steering shaft has to be disconnected at the EPS motor in order to be able to gently centre the steering wheel and the steering rack, then reconnect the shaft to the motor.
Now , please note , do not turn the steering wheel fast as the clock spring maybe damaged. If the steering wheel moves by itself, it’s probably the clock spring is already damaged.
Why did you pay for a new motor? They are under a lifetime extended warranty.
You need a professional alignment shop. The previous guy screwed something up really good. I suspect a pretty bad "accident".
An accident would have bent tie rods to pull the steering wheel out of time like that. I believe you’ll find the intermediate steering shaft was disconnected and the steering wheel was turned but not aligned correctly when it was replaced
That is my thought. I’m going to try and redo that process with the proper alignment of the shaft and wheel tonight. Thank you.
