Price to repair control arms
The flat rate is 1.8 hours + about $202 each for GM parts. (based on a 2015 database) Gmpartsdirect quotes $236 retail/$146 internet each.
If you can find a independent shop that will use your parts they are much cheaper on Ebay. Not a difficult job for someone with a few tools.
Control arms
I paid $150 for my lower control arms from Amazon. There are actually three different types of suspensions FE5, FE3 and FE1. The FE5 and FE3 suspensions use an aluminum lower control arm whereas the FE1 uses a steel lower control arm.
I had my control arms replaced and installed with a wheel alignment for about $500. That also included putting Energy Suspension sway bar bushings on.
The major difference in the FE5 part is the ball joint. Unfortunately, most of the parts books are unaware of this fact, including the GM book.
Many are confused because they ASSuMe that all Cobalt parts interchange with HHR.
DwHhr2LT
Sep 29, 2012 08:25 AM
