Programmed TMPS sensors
If you have a tire tool to break the bead of your tires then you can remove the valve stem and sensor and install the new one. Mounthem on your HHR and follow the installations in your owners manual to relearn them . You will need a tool for that
https://images.app.goo.gl/C99v8axNpYEM1bMv7
camaro98z28
Jul 11, 2009 08:26 PM
