proper way to install oil filter ?
Old Aug 3, 2021 | 04:20 PM
ScareDe2's Avatar
When I try to screw the cap by hand with the oil filter I can never hand tight it completely. And I use OEM Delco and brand new cap. For me it is just proof that a resistance is added because the filter is not perfectly aligned inside.
Old Aug 3, 2021 | 05:46 PM
So, the proof would be to install it the way everybody else does, then take it right back out to see if it's crushed or twisted.
It's not supposed to be hand tight. 18 lbs ft is the specification.
Old Aug 3, 2021 | 06:26 PM
tiapetra's Avatar
You folks are over thinking this and some of your conclusions are wrong.
1st, it doesn't matter which way you install the filter. That's NOT when it gets crushed, twisted or whatever you want to call it. The filter gets twisted when you take it out after being used. That's because it has been soaked with oil and is "soft". So, when you unscrew the cap, the "soft" wet filter gets twisted as the cap rotates.
Yes, some of the better made filters may not twist (as it was stated above.)
I've used the cheap Fram filters before(twice they came out twisted)
Used the AC Delco's (one came out twisted, the other 2 or 3 didn't)
Interesting theory, bound to happen with the cheaper paper filters, more so after saturation than before.
The Delco filters don't seem soft after use. Just did an oil change 2 days ago and the filter was pretty stiff.
Old Aug 3, 2021 | 09:33 PM
Odd... Mine has never looked "crushed" when I changed it.
Likewise, mine neither, & I have been changing it's oil since 2009, filter always comes out straight.
Old Aug 4, 2021 | 03:12 AM
ScareDe2's Avatar
Maybe it has to do with the car not being level. Once the filter is snap to the cap it can still move a bit. If it is being screwed there without being perfectly centered in its cavity it creates a stress on the filter. Let's suppose it is impossible for the filter to not be installed correctly, then it's the stress from the ratchet that damage the filter and cause it to collapse after some miles of use. My theory.
Either way, it should be possible to hand tight the cap until you can barely see the seal, then screw it with the ratchet (to the specification). The best possible way to insure it is done perfectly is by centering the filter inside its cavity first.
Old Aug 4, 2021 | 10:35 AM
  #26
tiapetra's Avatar
Hence the post with the oring on the bottom has a point on it.
If it fits tight enough for an oring to compress, then it is automatically centered.
Old Aug 4, 2021 | 07:45 PM
  #27
Yep.
Old Aug 26, 2021 | 04:10 PM
  #28
haX0r's Avatar
Either way is fine.
Like putting a new roll of toilet paper on the holder. Should it dispense off the top or the bottom ?
Again, either way is fine.
Actually, TP over the top is the correct way. At least according the the patent filing. :)
Old Dec 26, 2021 | 04:32 AM
  #29
Squibt's Avatar
Quick lube oil change does this….
Quicky Lube…looks crushed…maybe filter too big
Old Dec 26, 2021 | 06:37 AM
  #30
Not sure what you mean by "looks crushed...maybe filter too big". (maybe you posted the wrong picture ?) All I see is the filter cap and a very clean area around it.
