Pulled Wires out of Headlamp socket
Old Dec 20, 2016 | 02:11 PM
HHROrange's Avatar
I foolishly forgot about the release tab on my headlights and yanked it
This pulled the wires out of the headlight socket. I was able to get the wires back in the right slots and the light to work briefly but i can't get them to stay in the back of the connector. Anyone have any thoughts or ideas on what i can do? It would be like if you pulled the wires from the back of this and needed to get them to sit back inside again http://img.ptimg.com/is/image/Autos/p45239008hd_1?
Old Dec 20, 2016 | 05:50 PM
Cut and connect the wires done!
Old Dec 20, 2016 | 06:50 PM
HHROrange's Avatar
Thanks, the ends are still intact, but trying to get them to stay inside the socket is the difficulty. I can push them into their specific holes but can't get them to stay in there once I move it. Are they just not in far enough? Is there something that should lock them in there?
Old Dec 20, 2016 | 06:54 PM
You've probably stripped out the plastic "catch" tabs that hold the wires in the socket.
Best to just replace the socket assembly.
Old Dec 20, 2016 | 08:04 PM
HHROrange's Avatar
Thanks FMG
Old Dec 20, 2016 | 08:28 PM
If you are talking about the brass/copper ends that pulled out of the plastic housing that the wires are attached to, the copper ends often have a little prong that catches inside the housing to prevent them from being pulled out. If the prongs are bent, they won't catch inside the housing. Bending the prongs back so they stand out slightly will help them catch inside the housing, preventing them from being pulled out.
If the wires themselves have been broken away from the copper contacts, one can remove them from the housing by inserting a thin screwdriver, or such, to press against that prong that hold them in place - resolder, and reinsert into the housing.
Old Dec 21, 2016 | 06:34 PM
If you really want to save a few $ at the expense of time and aggravation the pin can be bought and replaced.
But, your local Auto Parts store will be able to get a new plug if they don't have it in stock.
edb
Jul 28, 2008 11:04 AM
MikeX
May 18, 2006 05:48 PM
