Pulling to the left ?
Old Jun 7, 2012 | 10:07 AM
What solman said.
Old Jun 7, 2012 | 10:57 AM
Originally Posted by solman98
Do you mean directional tires mounted backwards? If so, that still shouldn't affect normal driving, just not the best handling from the tire.
x3 - Goodyear: "Tires with a "directional" tread design are intended to roll and perform in a given direction. The sidewall will have arrows indicating the rolling direction fo the tire. If installed in the wrong direction the tire will not perform its intended function. However, no damage or premature wear to the tire will result. The tire should be dismounted and remounted to roll in the proper direction. "
Old Jun 7, 2012 | 04:34 PM
Doc brown's Avatar
Originally Posted by dustin6119
replaced rotors
Hmm...
Check your slide pins and calipers. The slide pin "head" where the caliper bolt goes in has an oval shape with flat sides to it. It only fits one way, and if its not fully seated it will cause part of the outside pad to pull inward and drag on the rotor, and of course pull a little bit. I know, because I did this very thing on my HHR once.
Old Jun 7, 2012 | 08:06 PM
TomsHHR's Avatar
Through a new set of tires brakes and rotors and even an alignment (4 wheel) My 2006 had a slight left pull for 5 years..
Old Jun 8, 2012 | 04:48 AM
dustin6119's Avatar
as of right now I have to roll with what Tom had said.....that seems to me the most likley.....in my opinion...gimme a week are to to get it all done and we'll see.. thanks Tom.
Old Jun 11, 2012 | 09:16 AM
Let us know how things go with your HHR. I hope you had a great weekend.
Old Jun 11, 2012 | 09:35 PM
dustin6119's Avatar
I will it will be a work in progress as I get time....the pullintg and vibration isn't bad at all I'm just being really picky....it'll take time to track down..
Old Jun 17, 2012 | 08:15 PM
Dean_Dorholt's Avatar
My 2009 with 83K has had this pull also. If the lane is pitched a lot to the right it's ok. New set of Michelins (top of the Line), 4 wheel aliment tech said it was within spec. The only thing he thought to try was an adjustment to the left rear wheel but it’s not adjustable. Something I have to live with. Dangerous when texting and driving. LOL!
Old Jun 17, 2012 | 09:06 PM
havoc3d's Avatar
Just reporting in with the same issue in my 08 SS. Had it for 30k+ miles now and it's always had just a slight left pull... If I let go of the wheel at speed it will start to cross the lines pretty quickly, but it's only a couple of degrees of right turn to correct it. The weight of my hand pretty much evens it out.
TEKNOnaut
15
Oct 14, 2012 12:13 AM
ufvj217
Feb 7, 2011 07:45 PM
1970judge
Apr 14, 2010 04:50 PM
ChevyMgr
Racing Discussion
17
Jun 3, 2008 02:51 PM
bigdog9586
May 24, 2008 10:27 PM
