Question about coolant recovery tank
I have a 2008 2LT with 2.4L engine (about 40K miles) and I just want to make sure I'm looking at the correct spot for the "cold fill line" on the coolant recovery tank when I do my visual inspections. It's difficult to tell from the owners manual (page 5-25) as the picture isn't exactly detailed.
I put a flashlight down there (on the left side when facing the car) and saw a "bump" on the back of the plastic tank pointing towards the engine. The coolant level was a little above the top of that mark. Am I looking at the correct spot and am I correct i assuming that my coolant level is ok? With the hot weather here I just want to be sure!
Here's a photo. https://www.chevyhhr.net/forums/main...ank-pic-55772/
Thanks to everyone for your help! That picture in the manual leaves a LOT to be desired!!!!
Donbrew, thanks for the advice, my coolant level is right about at the same spot as in FMG's picture. Right at the top of that "notch" near the bottom of the tank.
SSROADSTER
43
Mar 7, 2022 08:46 PM
