Radiator Drain plug
Old May 1, 2008 | 12:41 AM
Cardwiz428's Avatar
Radiator Drain plug
Anyone know where is the radiator drain plug located? Also, what type of antifreeze (quantity & type is recommended?
Old May 1, 2008 | 08:55 AM
solman98's Avatar
Can't tell you the loaction of the drain, haven't looked for it.
But the entire system holds 48.6 quarts of Dexcool for the 2.2. (51.8 for the 2.4).
Now how much drains is a different story........
Old May 1, 2008 | 01:23 PM
Snoopy's Avatar
You made some type of mistake, Solman.... The capacities are incorrect. From the Owner's Book.....
Capacities and Specifications
The following approximate capacities are given in English and metric conversions. Please refer to
Normal
Maintenance Replacement Parts on page 405
for more information.
Application
Capacities
English Metric
Air Conditioning Refrigerant R134a
For the air conditioning system refrigerant charge
amount, see the refrigerant caution label located
under the hood. See your dealer for more
information.
Cooling System
2.2L Engine 7.4 qt 7.0 L
2.4L Engine Manual 8.7 qt 8.2 L
2.4L Engine Automatic 8.5 qt 8.0 L
Engine Oil with Filter 5.0 qt 4.7 L
Fuel Tank 16.2 gal 61.3 L
386
Old May 1, 2008 | 01:45 PM
solman98's Avatar
Normal
Application
Capacities
English Metric
information.
Cooling System
386
just going off the spec sheet for a total engine fill.
Capacities
EPA interior volume (cu ft / L): TBD
Passenger Volume (cu ft / L) 97.4 / 2758
Cargo volume (cu ft / L): 63.1 / 1787 (with rear seat removed)
GVWR, standard (lb / kg): 4173 / 1893 (preliminary)
Payload, base (lb / kg): 900 / 408
Trailer towing maximum (lb / kg): 1000 / 453
Fuel tank (gal / L): 16.2 / 49
Engine oil (qt / L): 2.2L and 2.4L: 5 / 4.7
Cooling system (qt / L): 48.6 / 46 (2.2L); 51.8 / 49 (2.4L)
Old May 1, 2008 | 04:36 PM
ChevyMgr's Avatar
Drain plug is on the right hand (passenger side) of the radiator. When you lift the hood and are looking at the engine, it will be on your left. You can look down the side of the radiator with a flashlight and see it.
But it is easier and advisable to just remove the lower radiator hose if you are want to drain it. Also take the pressure cap off to allow the air/gravity to assist in the draining. Those drain plugs are plastic and break easily.
Old May 1, 2008 | 05:04 PM
davidforetexas's Avatar
hhr drain plug location
It is located on the bottom right of radiator, and as i previously saw a correction in cooling capacity, it is 7.4 qts. Hope this helps
Old May 1, 2008 | 06:44 PM
Snoopy's Avatar
Capacities
I thought what I posted IS THE TOTAL replacement. Think about it, car is required to have a 50/50 mixture of anti-freeze and drinkable water. Dealers do the service for XXX amount of dollars (generally less than $100.00) and use 4 qts, (1 gallon) to 5 quarts of antifreeze. If this is all they exchanged , that would make much less than a 50/50 mixture. If they mantained the 50/50 mixture it would take roughly 24 quarts.
But, I would ask ChevyMgr or one of the service tech's to intervene with the correct answer. This is a critical area to make a mistake. And I would really like to know.
You wouldn't be taking that data from the "old" GM media release, would you?? There was an admitted error in several areas, including this and HP, if you remember.
Old May 1, 2008 | 06:57 PM
an08HHR's Avatar
48 quarts is 12 gallons, the size of gas tanks in some cars.
Old May 1, 2008 | 10:16 PM
ChevyMgr's Avatar
...and thats too much when your talking coolant/antifreeze.
1 gallon (4 qts) of coolant and 1 gallon (4 qts) is the maximum you would need on any repairs.
Old May 2, 2008 | 12:05 AM
Cardwiz428's Avatar
Thanks folks, Really appreciate the help!
