Radiator Drain plug
Old Dec 10, 2008 | 03:58 PM
dewit's Avatar
Thanks for the info, I have to change my thermostat and I was going to just pull the bottom hose off. Boy I wish I could get a service manual without pay over 100 dollars for it. But It it probably be worth it. Thanks again for your information.
Old Dec 23, 2013 | 10:55 AM
rkarenas's Avatar
Also, if you don't buy a pre-mix 50/50 engine coolant do not use tap water as your 50/50. Use Distilled water. Tap water can have deteriorating effects with the different metals it will be in contact with. Same goes for flushing the system. Use Distilled water.
Old Dec 23, 2013 | 10:57 AM
rkarenas's Avatar
Go to Haynes for a HHR service manual under $25.00. http://www.haynes.com/products/?sear...l=HHR&x=10&y=4
Old Dec 23, 2013 | 11:51 AM
4 year old thread?
Old Dec 23, 2013 | 03:21 PM
There is no problem using tap water, unless there is a known problem with your tap water. Use distilled water if it makes you feel better............... Distilled can't hurt, but isn't absolutely necessary in most cases especially if one follows the recommended flush/fill schedules.
Old Dec 23, 2013 | 04:04 PM
I agree whopper.
Plus. Do you actually think that "all" the antifreeze manufacturers only use distilled water in their mixing/dilution process? I doubt it.
Old Dec 23, 2013 | 06:36 PM
Lucky's Avatar
I agree whopper.
That's a good point. I have always used tap water. All the dealers that I have worked for never had distilled, cooling systems were always mixed and topped off with tap water
Old Dec 23, 2013 | 06:52 PM
It still is a 4 year old thread!!!! With nothing new added.
Old Dec 23, 2013 | 07:09 PM
Lucky's Avatar
I see nothing wrong with adding a few small comments to a 4 year old thread that a new member dug up.
At least he is using the search bar.
We have added two pages so far to a 4 year old thread that is still on the subject of introduction.
Old Dec 23, 2013 | 07:59 PM
And it morphed from a question about the drain plug on the radiator into a discussion about distilled vrs tap water - which is semi-related, sort of.
But good point about the usage of the search tool/bar.
anyways, gonna close this before it morphs into a discussion about the availability of a lock for the glove box.
- Closed!!!
slantram
Maintenance and Upkeep
Jul 10, 2014 09:25 AM
logcar
18
Oct 21, 2011 04:19 PM
RICK167448
Apr 13, 2011 12:19 AM
steveshow
2.0L Performance Tech
Mar 17, 2009 02:03 PM
Cardwiz428
2.2L Performance Tech
May 26, 2008 06:05 PM
