Radiator fan not working 2006 hhr lt
Old Jun 7, 2019 | 09:35 AM
Roy Nettleton Jr's Avatar
Jumpered the fan works fuses good fan doesn't work with ac on and I have this sensor broke unsure what and where it goes. Located above alternator somewhere I believe due to wire
Unsure what sensor it is
Old Jun 7, 2019 | 09:57 AM
My guess is that is the refrigerant pressure sensor. That is probably why the fan does not go on when AC is on; does it work otherwise?
Old Jun 7, 2019 | 10:02 AM
That doesn't make a whole lot of sense. Can you explain how you have a sensor in your hand and you don't know where it goes?
Old Jun 7, 2019 | 10:05 AM
My super power led me to believe he meant he found it hanging off the wire.
Old Jun 7, 2019 | 10:19 AM
THIS. The silver part in the red circle.
Old Jun 7, 2019 | 10:20 AM
Yes was hanging down and no fan doesn't start till I directly add power by jumping it
Old Jun 7, 2019 | 10:38 AM
Trying to to put in toggle switch unless I need to for now
Old Jun 7, 2019 | 10:42 AM
could this be it and if so could this cause fan not to run
Old Jun 7, 2019 | 10:55 AM
That's the part but you have a problem.
Looks as though you've broken off the pipe that the sensor screws into. Not sure but that pipe may be integral to the hose block. You may have to replace that whole assembly to be able to reinstall the sensor.
Old Jun 7, 2019 | 11:15 AM
ahhhhhhh
