Radio Fuse Parasitic Draw...
Old Mar 26, 2024 | 12:25 PM
Hoss440's Avatar
Originally Posted by Oldblue
If you unplug the radio itself does the drain go away?
Havent tried pulling the actual radio yet. First figured out that if I pull the bcm fuse in the back by the battery the drain goes away. And then tracked it down to the rdo fuse causing a drain.
Old Mar 26, 2024 | 12:28 PM
Hoss440's Avatar
His bio shows the car is a 2008 model. Since that year had the known issue dealing with power loss affecting the programming , I would be careful about disconnecting any power wires while diagnosing.
Also which radio ? Regular or the upgraded one with the separate amp ?
Has original factory radio without amp. Just replaced battery recently because the parasitic drain would deplete the battery within a few days if I didnt drive it.
Old Mar 26, 2024 | 12:33 PM
Hoss440's Avatar
Originally Posted by donbrew
What year is the car? Which radio?
Does the fob work as expected? Does the TPMS work? Is Onstar, XM/Sirius in the car, activated or not? Do you have the "Premium" radio with sub woofer and amp, steering wheel controls
Which fuse are you calling the "radio fuse"? Has ANY work been done before this started?
If the RAP relay was stuck you would be able to operate the windows when you first enter the car. If the RCDLR was involved the TPMS and fob would not work correctly, it is always hot on the same fuse as the radio.
What is the full code causing the CEL? One of them means "short to voltage".
The RDO fuse is always hot, the radio is turned on/off by a digital signal from the BCM, not the RAP relay.
Have you made sure that the dimmer wheel is not ON? Not all years have that.
Are all of the door switches operating correctly? Including the lift gate? Is there a fuse in position #11 under hood?
Give me a couple hours Don and I'll give u answers to all that.
Old Mar 26, 2024 | 04:26 PM
I was aiming for a process of elimination, but carry on.
Old Mar 26, 2024 | 08:11 PM
The fuse at the battery powers the BCM,, no surprise the drain would go away since the BCM is always on.
SwiftAnalog
Sep 28, 2021 06:32 PM
bluwing
Sep 6, 2016 04:28 PM
journey4
Oct 4, 2014 04:33 PM
john
Jan 23, 2012 08:09 PM
JG27AD
Jul 30, 2009 01:59 AM
