Rattle Under Steering Wheel ONLY WHEN AT STOPS, HOLDING CAR BY BRAKING
Old Mar 27, 2021 | 06:31 PM
LucasMultivariablePi's Avatar
Angry Rattle Under Steering Wheel ONLY WHEN AT STOPS, HOLDING CAR BY BRAKING
I have gotten a tire balance, replaced lower control arms, rotors, brakes, motor mounts, front struts, alignment.
The rattling sounds like its coming from the inside of the cabin, SPECIFICALLY, near the brake and acceleration pedal, but I know its steering related because when I brake, ONLY when I brake at stoplights, the rattle is present. Sounds like plastic rattling, but I'm not too sure. The rattle IS NOT there when I have the car in neutral or park. It is only when the car is in drive or reverse. I am not sure what it could be.
Old Mar 27, 2021 | 07:33 PM
to the forums!
You could check the engine mount. There is a port in the passenger wheel well, if the bolt for the belt tensioner is sitting low, your mount needs replacement.
Also check for vaccum leak near the brake booster. There's a plastic elbow where the line attaches to the booster. This has been known to break.
Old Mar 28, 2021 | 07:06 AM
You don’t mention sway bar bushings, sway bar end links, intermediate steering shaft , plastic fender liners , front bumper cover, windshield cowl
Old Mar 28, 2021 | 09:37 AM
I'm thinking it might be something dragging down the idle speed.
Old Mar 28, 2021 | 09:52 AM
Isn't intermediate shaft on the radar?
Old Mar 28, 2021 | 10:13 AM
Bottom line, something is loose. It rattles when idle speed is at it's very lowest speed, which is idling in gear and holding brake. You might just start wiggling things around under the dash, see if you can make something rattle.
Otherwise, get a helper to hold the brake pedal(or set the parking brake, wedge the brake pedal) and start investigating all areas of the car, because there are a lot of potential sources for a rattle noise.
Old Mar 28, 2021 | 10:18 AM
The plastic knee panel under the steering wheel and the knee panel behind it, the garage door remote, mine rattles , very annoying!
there’s more, after you check all these!
jwbrookhouse
Nov 10, 2021 04:33 PM
MCHHR
Oct 4, 2016 03:00 PM
nbasso85
Aug 16, 2012 10:56 AM
RStruthers
Jul 7, 2012 10:50 AM
spotty
Feb 24, 2012 08:58 AM
