Rear hatch leak
Old Apr 17, 2014 | 07:17 PM
Blobbo's Avatar
Rear hatch leak
Just bought an '06. We had snow today and I have water coming in from the upper passenger side corner of the rear hatch. The trim is sagging a little so this problem isn't new. Any ideas?
Old Apr 17, 2014 | 07:49 PM
Lucky's Avatar
Do you have a roof rack? If so make sure the the bolts that hold it to the roof are tight
Old Apr 17, 2014 | 07:59 PM
If you're not equipped with a roof rack, check the weatherstrip for tears and cuts.
An old mechanic's trick to see if the weatherstrip is sealing effectively it to take a dollar bill and place it in various locations then close the hatch. If the dollar pulls out with a good bit of resistance, the seal is good. If you can just yank it out, then the weatherstrip is getting tired, or the hatch is tweaked a bit.
Also have someone sit in the back while you run a stream of water from a garden hose all around the hatch and rear window. It could be leaking around the glass.
capp002
Dec 10, 2020 07:57 AM
Blue Beast (aka Boydie)
Jul 16, 2013 04:55 PM
xzombiex66
17
Aug 8, 2009 09:02 PM
duck65
Dec 6, 2007 11:11 PM
